Saint_Dad
Aug 15, 2022Aspirant
CM1000V2 DS light flashing but internet connection is great
A couple of weeks ago the downstream light on my CM1000v2 started flashing. I've been using this modem since March of 2020. The light becomes solid green with a reboot, but it only lasts for 1 to 4...
- Sep 22, 2022
Problem solved. Replace the section of coax in the attic. The connectors were installed poorly. Used a quality quad shied rg6 and compression connectors.
Saint_Dad
Sep 11, 2022Aspirant
Thank you for the suggestions. I’ll check the connection at the outside box. I’ve also looked at the line between the outside box and the wall socket for my modem. There a section that was added to extend the cable from the family to living room. It has been working fine for 20 years, but I plan on replacing it. After all the work on my end is completed, I’ll push more on Comcast.
Kitsap
Sep 11, 2022Master
All the more reason to check it carefully and/or have it replaced!
- Saint_DadSep 22, 2022Aspirant
- KitsapSep 22, 2022Master
Glad you have it taken care of. Please mark this issue as resolved so others can benefit from the discussion.
