Roofius
Nov 03, 2023Aspirant
CM1000v2 Flashing lights, is it burned out?
Hello. Does anybody know what a Green flashing Power light, Amber flashing Upstream/Downstream/Online and Solid Amber for Ethernet all means. These indications are not listed in the User manual and I ...
- Nov 05, 2023
Sounds like it's needs replacing.
Nov 03, 2023Guru - Experienced User
What does the user manual say about LED behaviors?
Can you access the modems web page at 192.168.100.1? If so,
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
- RoofiusNov 03, 2023AspirantThe only LED that the manual has any meaning for is the Ethernet light. Solid Amber means a powered device is connected to the LAN port and I have disconnected the router from it and it still lights up.
I cannot connect to my modems web page. I reconnected the router when I tried this and got nothing. My cable is rated for CAT6.- plemansNov 04, 2023Guru - Experienced User
Try disconnecting the coax from the modem. Then factory reset it and let it reboot with the coax unplugged.
I've seen a few times where a hot incoming line puts the modem in a reboot/hardware failure.If that doesn't fix it, its more than likely a hardware failure
- RoofiusNov 04, 2023AspirantI tried your advice. It didn’t work unfortunately.
