Roofius
Nov 03, 2023Aspirant
CM1000v2 Flashing lights, is it burned out?
Hello. Does anybody know what a Green flashing Power light, Amber flashing Upstream/Downstream/Online and Solid Amber for Ethernet all means. These indications are not listed in the User manual and I ...
- Nov 05, 2023
Sounds like it's needs replacing.
Roofius
The only LED that the manual has any meaning for is the Ethernet light. Solid Amber means a powered device is connected to the LAN port and I have disconnected the router from it and it still lights up.
I cannot connect to my modems web page. I reconnected the router when I tried this and got nothing. My cable is rated for CAT6.
Nov 04, 2023Guru - Experienced User
Try disconnecting the coax from the modem. Then factory reset it and let it reboot with the coax unplugged.
I've seen a few times where a hot incoming line puts the modem in a reboot/hardware failure.
If that doesn't fix it, its more than likely a hardware failure
