HyperFirez
May 22, 2021Tutor
CM1000v2 Frimware can't be updated remotely by ISP
Hi, I've been expiring this weird issue with Battlenet. Specifically the new Call of Duty games. I keep getting disconnected every 1.5 - 3 hours. I noticed that the frimware on my modem is higher tha...
May 23, 2021Guru - Experienced User
do you have an actual screen snip of the cable connections page and the event logs?
in terms of firmware, the firmware is bundled with the ISP's provisioning of your device.
Its not something the ISP is going to change sadly.
I'd doubt the issue is the modem if its only happening in one game. If it was multiple games/services, then I'd be more inclined to point fingers at the modem.
If you direct connect your console to the modem and use it, do the drops still happen?
- HyperFirezMay 23, 2021TutorSo here are the pics. Also this is happening on my PC. I play on Battlenet and I think it's an issue solely with the PC version as it is a Battlenet errorcode.
- plemansMay 23, 2021Guru - Experienced User
photos have to be approved by a moderator. (it can take a while)
If the pc is directly connected to the cm1000, does it have the same issues?
Yes it does. I also had a Cox tech come out and hook in directly to it. He tried running a speedtest multiple times and the first couple of times it timed out. Eventually on the 4th/5th time it worked. He said at that point he believes it has a hardware defect
