HyperFirez
May 22, 2021Tutor
CM1000v2 Frimware can't be updated remotely by ISP
Hi, I've been expiring this weird issue with Battlenet. Specifically the new Call of Duty games. I keep getting disconnected every 1.5 - 3 hours. I noticed that the frimware on my modem is higher tha...
HyperFirez
May 23, 2021Tutor
So here are the pics. Also this is happening on my PC. I play on Battlenet and I think it's an issue solely with the PC version as it is a Battlenet errorcode.
May 23, 2021Guru - Experienced User
photos have to be approved by a moderator. (it can take a while)
If the pc is directly connected to the cm1000, does it have the same issues?
- HyperFirezMay 23, 2021Tutor
Yes it does. I also had a Cox tech come out and hook in directly to it. He tried running a speedtest multiple times and the first couple of times it timed out. Eventually on the 4th/5th time it worked. He said at that point he believes it has a hardware defect
- plemansMay 23, 2021Guru - Experienced User
Did he hook one of their modems to it?
Not entirely sure what it was. It was a really bulky handheld device with plugs for ethernet and coax cables. It also had a touchscreen on it.
