Tom_Z
Feb 01, 2020Aspirant
CM1000v2 having poor speed test results
Just bought a CM1000v2 cable modem. Went through set up with xfinity. It works but speed is very poor. I have 300 mbp service and speed test only shows 33 mbps. Xfinity says everything is fine on the...
- Feb 03, 2020
Has the modem been factory reset. Press the reset button for 15 seconds then release.
It's also possible that you have a faulty unit which needs to be replaced.
Tom_Z
Feb 02, 2020Aspirant
Adding screenshot of cable connect details in case that provides any additional insight??
