NeilU
Feb 28, 2023Guide
CM1000V2 modem cannot connect computer
CM1000v2 is connected to Optimum cable and Orbi 04 mesh. I am getting increasing frequency where internet drops completely even though the modem shows signal. If I hit the restart on the modem it q...
NeilU
Feb 28, 2023Guide
Ouch
What I was hoping was I could segregate the issue of whether the internet signal was actually getting through the modem. That would explain why I could not just bypass the connection to the router to see if I am getting real thru-put into the router.
The modem usually would to show internet signal was strong when it has gone down which again is a question of whether it is the modem or the router. Unfortunately I haven't tried restarting just the router in the past - I keep restarting the modem and that causes the router to also to go through a reboot. And since the only time I get to check this out is when I get a crash I can't just check things out at will.
Would resetting either or both devices help in the future?
Feb 28, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Please give feedback to the questions presented as well...
- NeilUFeb 28, 2023Guide
The Firmware is V1.01.03
The log and status pages are quite a bit -
Here is a screen shot for one of the pages. Not sure which is most useful.
Right now we have too much ZOOMING going on in the house for me to do some of these restarts.
I did find an older router I can hook up if I get a crash again to see if I can still get signal through the modem. (an older Netgear, not a mesh)
I can try what has been suggested for doing a better restart for both modem and router and will do those when I can work when everybody is free from internet
- plemansFeb 28, 2023Guru - Experienced User
Your power levels or out of spec (high) and you're getting non locked channels.
Start with removing any amplifiers from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.You might try adding in a triple splitter or signal attenuator to bring the power level down within spec. Just use a good quality one.
- FURRYe38Feb 28, 2023Guru - Experienced User
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Can you post the Events Log page as well?
