NeilU
Feb 28, 2023Guide
CM1000V2 modem cannot connect computer
CM1000v2 is connected to Optimum cable and Orbi 04 mesh. I am getting increasing frequency where internet drops completely even though the modem shows signal. If I hit the restart on the modem it q...
Feb 28, 2023Guru - Experienced User
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Can you post the Events Log page as well?
NeilU
Feb 28, 2023Guide
Here is the events page
I am curious about what constitutes high signal level.
There is one splitter on the cable when it comes into the house since one line use to go to a TV which I do not use. So the modem gets the main line coming in (after that one splitter that the ISP did install)
Nothing else attached to the line other than a connector box to extend the line.
