NeilU
Feb 28, 2023Guide
CM1000V2 modem cannot connect computer
CM1000v2 is connected to Optimum cable and Orbi 04 mesh. I am getting increasing frequency where internet drops completely even though the modem shows signal. If I hit the restart on the modem it q...
Feb 28, 2023Guru - Experienced User
If its still dropping, rent a modem from the ISP.
I've had to rent one for a month or 2 to prove to the isp that their line was causing the issue.
they fight tooth/nail to not have to fix issues until proven its their equipment.
And who knows, maybe it is the modem and something internal is causing the issue.
It isn't unheard of and is hard to distinguish the difference from an internal fault to a line issue
NeilU
Feb 28, 2023Guide
I had done some checking to find out what about their units which is when I was also told they would only reach into their rented version of Arris. But it has definitely been on my radar.
You have been very helpful in getting me back into troubleshooting mode (and digging into the hardware). A last (maybe) question. You mention that you are only seeing a part of the number of channels. The list shows a total of 32 (which makes sense in binary) and 28 are download.
But The Aquire Downsteam channel has a frequency 585 MH which is the same as only one channel - 25 which has a power level of 8.5 which is just in the acceptable. Can I assume that this is the only channel that is active in download since the others are all at different frequencies - what then are all the other channels for and does it matter that they are at much higher power?
- plemansFeb 28, 2023Guru - Experienced User
They're all used. Which is why a couple bad channels can create issues when the rest are fine.
- NeilUFeb 28, 2023Guide
I will leave it at this for now and will see what happens as I start some experimenting.
Thank you for your help
I just added a 3 way splitter next to the modem and WOW - the main channel is down to 0.5 and none are above 5.5.
Except now you have a ton of errors/uncorrectables. Which is just as bad/worse as getting the power in the right zone.
Whoops. Didn't see that, just looked at the power.
So I guess I should probably revert back. Hmm. Before there were practically no errors.
Oh boy.
So I changed the splitter to a two split and a different cable
Now the errors are only on 3 channels and the levels are significantly lower than originally.
I think I will leave it like this for now (unless those channels 25,27 and 28 would be important).
- plemansMar 01, 2023Guru - Experienced User
You're doing a juggling game. Because the power levels are still out of spec. All the channels should be within 3.5dbmv of each other or they'll have bonding issues. Yours go from 9.2dbmv to 1.2dbmv. a 8dbmv difference. So still out of spec.
It can bit a pita to do things like this. Its why signal attenuators were made. You can stick them in line and you don't have multiple connections that can be causing issues. Its why I also only used a single x4 block for mine and capped the other ends.
- KitsapMar 01, 2023Master
NeilU wrote:So I changed the splitter to a two split and a different cable
All of the channels that are shown as locked are important. None more so or none less so.
If there are problems with the signal levels on specific channels, that is the responsibility of the ISP to resolve.
The attenuator pads plemans mentioned are available from Amazon here: https://a.co/d/26Df1Ll. They come in different sizes ( 3 db, 6 db, 10 db). Make sure your buy those that cover the standard frequency range for cable TV internet systems (5 Mhz to 3 Ghz).
The connection caps plemans mentioned are also available from Amazon here: https://a.co/d/5ELepHl. They are important to prevent leakage that adds noise to your upstream signal.
- NeilUMar 01, 2023Guide
I am beginning to understand. I thought we were talking about putting a splitter but an attenuator is something totally different.
I am now getting all kinds of errors so I am understanding - I will get a set of the three sizes and a set of caps.
Thank you
NeilU wrote:I am beginning to understand. I thought we were talking about putting a splitter but an attenuator is something totally different.
Thank you
By design, passive (non-amplifying) splitters add a certain amount of attenuation. Unless the label was removed, the output connections are usually marked as -3.5 db or -7 db.
Thanks for the links Kitsap
Like Kitsap says, a passive splitter acts as an attenuator. But the problem comes down to it adds more connections/more chances for issues. And they can be poorly made. Like I said, the only reason I used one was I had it sitting around.
Best bet?
direct connect the modem right to the cable coming into the home. That should give you your power levels to know what attenuator to buy. If you're getting 12-13 buy a 6db attenuator. I've found its better to be a little hot with the signal (5-7dbmv) versus to low.
Get the attenuator and connect it directly to where the cable comes in the home and then connect the modem right off that. With zero splitters.
Then check signal levels/errors and use it for a bit to see if it stays stable.
If it doesn't, the line outside the home needs to be checked.
I have a direct cable ready to put in place - probably this evening when we are not online. Then I can see just how that helps.
The attenuators and caps are from Amazon and I will see if I need any of that - if not they are easy to return.
I will be able to see how things progress since I have a bunch of screenshots over the last day for power and errors.
- NeilUMar 04, 2023Guide
Here is an update. Late yesterday I got the 10 db and installed it. After restarting it cleared up all the codes and lowered the power. I have watched this for a full day and this is the levels and codes after a full day - correctable had been down to 0 except for the first and last few. Power had been down to -2.8 for the first channel and now is down to -6
Others are in a tight spread.
I just received the 3db and tomorrow the 6db arrives.
I can replace the attenuator with the 6 to see if that is better.
- plemansMar 04, 2023Guru - Experienced User
I'm betting they'll need to check the line. You've still got channels going from -6 to +3.0. So a 9dbmv difference. Again, it should be within 3.5dbmv of each other.
so something is causing issues with the power levels. When they come, I'd pull out the attenuator.
- KitsapMar 04, 2023Master
I will second what plemans says about pulling attenuator.
When you are keeping screen shots of cable connection for records, be sure and include the system uptime at the bottom. The correctables/uncorrectables values accumulate since the last modem boot time. Knowing the time frame the numbers accumulated over is big part of the evaluation. If the numbers are big and you do not know whether they accumulated over a few hours, a few days, or a few months, then it is difficult to put them in perspective.
There are definitely some issues with the channels in the higher frequencies.
The screen shots are time stamped and I identified which one was when the system got restarted and essentially all set back to zero.
I didn't look at how the channels are increasing by frequency. Yes the problems are at the high frequencies - there is a definite distribution of errors at the 603 MH level with the primary channel (if I assume the one listed as 1 is such - id 28)
Here is a question - now I see the "Frequency Start Value" which I can enter any value.
What is an appropriate one to be putting there or does it matter?
I changed the number and it immediately went to reboot. whoops
Well It now restarted and everything is set to zero on correctable and uncorrectable and the value I tried as starting frequency was ignored. So we have a new beginning set which I can track again.
So now I need to understand what the implication of issues at different frequencies.
NeilU wrote:The screen shots are time stamped and I identified which one was when the system got restarted and essentially all set back to zero. Including the System Up time in the screen shot makes this simpler.
What is an appropriate one to be putting there or does it matter? Best to leave that alone. Does not change the end information.
I changed the number and it immediately went to reboot. whoops See above.
The laws of physics control that happens at the higher frequencies. The power levels will naturally decrease as the frequency increases. This where your ISP comes in to play and where they have responsibility. There are amplifiers along the path in the ISP distribution system. The amplifiers are grouped to cover four or five channels at a time. The gain on the amplifiers can be adjust by the ISP. This happens remotely from the location where the CMTS (Cable Modem Termination System) is located. In your situation, it looks like a higher frequency amplifier in the path is bad. There can be several of these amplifiers in the path depending on how far you are located from the CMTS.
I did no go back and reread the whole thread. Your coax cable should be RG6. It might show RG6 or series 6 stamped along the edge. If it is older coax, it should be replaced.
- NeilUMar 12, 2023Guide
Thanks for all the input previously.
I installed a new RG6 cable all the way from input to the modem.
I first installed the 6db - this was a week ago. That yielded a couple of +2 and above with many at about +6 to 7
Later I installed the 10db and now the values were from about -4 to +3.5 after restart. No uncorrectable for almost a day and then on 6th I rebooted and have tracked ever since.
Within a day it started to get errors which would sit for some length of time and then every so often it appeared to do some sort of power shifting and then hold with errors for up to a day or so. The primary highest channel would also jump from maybe -6 to -3.9 to -1.3 and each time maybe hold for half a day or so while the number of uncorrectable codewords would hold and then jump.
The latest attachment is since March 6.
I am going to vacationing for the next week so I won't be able to watch this now and may do a reboot before we leave and revisit in a week.
This is the latest screen shot - The total number of unerrored seems doesn't make sense over time. For a number of days the total codewords were constant across all the channels. Suddenly Channels 27 and 28 were much lower than all the rest which then remained the same continuing until now.
- KitsapMar 13, 2023Master
NeilU wrote:Thanks for all the input previously.
You are making good progress on the signal power levels. There are still a lot of uncorrectable line errors over several days.
The line errors should be the responsibility of the ISP for wiring outside your house.
- plemansMar 13, 2023Guru - Experienced User
If you've done what you can, the isp needs to check it.
