lbruski43
Jun 13, 2023Aspirant
CM1000v2 modem with slow speeds of 256mbps
I have a Netgear CM1000v2 modem and a r8000p router and 1.2 gig service. Speedtest download speed only around 256 mbps. Both modem and router capable of gig speeds but not getting it on speed test . H...
- Jun 23, 2023
Any Criticals, Errors or Warnings seen in the NG modems event logs needs to be reviewed by the ISP and resolve by the ISP. These indicate a signal line issue from the ISP.
Jun 13, 2023Guru - Experienced User
Are you seeing near 900Mpbs with a ethernet connected PC to the CM modem with out the router in the middle?
Be sure to use Ooklas installable speed test app for Windows and Apple
- lbruski43Jun 13, 2023AspirantThank you Furrye38 for your quick response. I read where I could test this way but have not done yet. I will do this as soon as other users are off line and respond back. Should complete in a couple hours. Would appreciate you checking back in after my response.
Thanks again !!- FURRYe38Jun 13, 2023Guru - Experienced User
When you can please post the following:
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerBe sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- lbruski43Jun 13, 2023AspirantPosted results from status you requested. Yes , when I bypass router I am getting 900 plus mbps so it appears I am getting my gig speeds from Xfinity. I then reconnected to router and tested different angles on my router antennas but best top speed was around 650 mbps. These tests were done sitting in front of modem and router. I then went to my living room where I use my iPhone and iPad . That is where I am only acheiving the average 250 or so mbps. I know walls and such cause distortion , but my Netgear modem and router make dels tout big whole house coverage . My home is only 2100 sq. Ft. I know moving the location of router/modem to my living room would help , but while sitting in front of them in current location , I could only achieve the 650 or so average , big drop off from the gig. Do you see anything abnormal or have any suggestions ?
Thanks !
