lbruski43
Jun 13, 2023Aspirant
CM1000v2 modem with slow speeds of 256mbps
I have a Netgear CM1000v2 modem and a r8000p router and 1.2 gig service. Speedtest download speed only around 256 mbps. Both modem and router capable of gig speeds but not getting it on speed test . H...
- Jun 23, 2023
Any Criticals, Errors or Warnings seen in the NG modems event logs needs to be reviewed by the ISP and resolve by the ISP. These indicate a signal line issue from the ISP.
lbruski43
Jun 21, 2023Aspirant
No , I have not completed a reset of modem . My modem and router were just plugged in and used with existing setups. No adjustments or resets done , as I am a novice at doing anything but plug and play. I fear doing the adjustments in fear of causing more problems.
Jun 23, 2023Guru - Experienced User
