Alpha1991
Jun 14, 2023Aspirant
CM1000v2 modem with slow speeds of 480mbps
I have been using my CM1000v2 Modem for the past six months. My plan with xfinity is 1200 Mbps. I recently gotten in contact with them and they send an electrician over. They fixed an issued on the ou...
Kitsap
Jun 14, 2023Master
Alpha1991 wrote:
I have been using my CM1000v2 Modem for the past six months. My plan with xfinity is 1200 Mbps. I recently gotten in contact with them and they send an electrician over. They fixed an issued on the outside but still have no more than 480-560 Mbps. I spoke to a rep online and she did all types of test and she tells me is my modem. While, I am still trying to figure out what happen. It has been going like this for the past 3.5 weeks. I usually get around 850-980 Mbps but this is by far less. Xinifty said is my modem, but I see there is a problem.
What is the brand name and model number of the router you have connected downstream of your CM1000v2?
Do you have a PC with an Ethernet port you can connect directly to your CM1000v2 for testing?
If yes, use the Ookla installable test application on the PC. Power down your modem and the PC. Power up your modem and give it plenty of time to boot and stabilize. Connect the Ethernet to your computer and boot your computer. Be patient, it might take a few minutes for your PC to get an IP address direct from your ISP.
- Alpha1991Jun 15, 2023AspirantWhat is the brand name and model number of the router you have connected downstream of your CM1000v2?
I am a bit confused by this, what do you mean? I thought that was private information. Sorry! New to all of this. I will send out what router log said.- KitsapJun 15, 2023Master
I am a bit confused by this, what do you mean? I thought that was private information. Sorry! New to all of this. I will send out what router log said.Just exactly what it says. You are complaining about the throughput performance of a cable modem, CM1000v2.
Downstream of that modem you should have a router of some unknown brand name and unknown model number that you connect to some unknown device where you are testing performance. Difficult to provide assistance without knowing what hardware is connected in the data stream path.
When you say send out what router log said, nothing is found. Where did you send it?
2023-06-15, 13:15:55 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 13:13:47 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 04:06:01 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 04:03:59 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 04:01:26 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 04:01:25 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 03:30:44 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 03:28:36 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 03:10:03 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 03:08:01 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 03:05:58 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 03:05:47 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 01:37:38 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-15, 01:37:32 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 17:49:06 Critical (3) Resetting the cable modem due to docsDevResetNow Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 17:19:42 Critical (3) Resetting the cable modem due to docsDevResetNow Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 16:03:29 Critical (3) Resetting the cable modem due to docsDevResetNow Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 15:50:46 Critical (3) Resetting the cable modem due to docsDevResetNow 2023-06-14, 14:06:27 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:06:22 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:03:45 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:03:43 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:03:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:03:35 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:02:01 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:01:57 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:01:56 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:01:55 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:01:55 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1; 2023-06-14, 14:01:55 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=bc:a5:11:8d:c4:84;CMTS-MAC=00:01:5c:86:f6:62;CM-QOS=1.1;CM-VER=3.1;
