jsaff1902
Oct 05, 2021Aspirant
CM1000V2 no sync
I bought a new CM1000V2 cable modem, it has the latest firmware V7.01.01. When my ISP activates the modem they tell me it's not syncing so I have not internet (no upstream signal). Every thing else...
Oct 05, 2021Guru - Experienced User
What is the brand and model of the host wifi router connected to the modem?
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
jsaff1902
Tests done by Comcast technicians both connected directly to pc and my Netgear R7000 router. Same result. Also tried resetting modem, it just will not sync. Because I did not purchase from an authorized dealer, Comcast can do no more.
- FURRYe38Oct 05, 2021Guru - Experienced User
You'll need to contact NG support and open a support ticket then.
