HyperFirez
Nov 05, 2020Tutor
CM1000v2 poor speed test results
As the title suggests I am having less than desireable speed test results after "upgrading" to this device. I was getting 900+ download, but I am only getting about 300-400 now. My ISP is Cox and I a...
- Nov 07, 2020
Had someone from Cox come out today. He determined that it wasn't the line after all. Nor a faulty modem. He fixed the upstream signal with some adapter thing that screws into the coax port then the coax screws onto it. Turned out to be my Windows was corrupted and the lan driver started acting up. I'm back up to Gigabit speeds now.
Nov 05, 2020Guru - Experienced User
Please post a screen snip of the cable connections pages and logs. Thats more helpful than saying you have some errors.
Also, I'd try moving the modem to right where the line enters the home and test speeds there. This ensures the lines within the home aren't causing the issue.
- HyperFirezNov 05, 2020Tutor
Here is the status pages: https://imgur.com/a/qgJNiko
- vkdeltaNov 05, 2020NETGEAR Employee Retired
did you try Speedtest app directly connected PC behind modem?
Yes I did. I am getting 300-400 download and 35-40 upload. Upload is the same, download is less than half.
