HyperFirez
Nov 05, 2020Tutor
CM1000v2 poor speed test results
As the title suggests I am having less than desireable speed test results after "upgrading" to this device. I was getting 900+ download, but I am only getting about 300-400 now. My ISP is Cox and I a...
- Nov 07, 2020
Had someone from Cox come out today. He determined that it wasn't the line after all. Nor a faulty modem. He fixed the upstream signal with some adapter thing that screws into the coax port then the coax screws onto it. Turned out to be my Windows was corrupted and the lan driver started acting up. I'm back up to Gigabit speeds now.
HyperFirez
Nov 05, 2020Tutor
Here is the status pages: https://imgur.com/a/qgJNiko
vkdelta
Nov 05, 2020NETGEAR Employee Retired
did you try Speedtest app directly connected PC behind modem?
- HyperFirezNov 05, 2020Tutor
Yes I did. I am getting 300-400 download and 35-40 upload. Upload is the same, download is less than half.
I just got done chatting with my ISP and they are sending a tech out on the 7th. Seems like my status compared to people with similar issues seems fine. So it might be the lines.
- plemansNov 06, 2020Guru - Experienced User
glad to hear you have them coming out. You're upstream values are way to low.
