dase2019
Nov 02, 2023Aspirant
CM1000v2 signal drops intermittently
I am losing internet intermittently. ISP is saying it is a modem batch error. The internet drops and then comes back within 60 seconds usually. I've tried rebooting, switching out LAN cable. Trying t...
Nov 02, 2023Guru - Experienced User
Whos the ISP?
Power levels are ok.
Only getting 16 channels though...what ISP Speed package do you pay for UP and DOWN?
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
- dase2019Nov 02, 2023Aspirant
ISP is Mediacom
Download speed paid for: 400mbps
Upload speed paid for: 30 MBPS
Router is EERO 6
- FURRYe38Nov 02, 2023Guru - Experienced User
Ok, that explains the channels not used.
- plemansNov 04, 2023Guru - Experienced User
The logs are still indicating all kind of line issues. Check your line as best you can yourself.
Move the modem to right where the line comes in from the ISP. If that doesn't help, they'll need to check the line
