dase2019
Nov 02, 2023Aspirant
CM1000v2 signal drops intermittently
I am losing internet intermittently. ISP is saying it is a modem batch error. The internet drops and then comes back within 60 seconds usually. I've tried rebooting, switching out LAN cable. Trying t...
dase2019
ISP is Mediacom
Download speed paid for: 400mbps
Upload speed paid for: 30 MBPS
Router is EERO 6
Nov 02, 2023Guru - Experienced User
Ok, that explains the channels not used.
- plemansNov 04, 2023Guru - Experienced User
The logs are still indicating all kind of line issues. Check your line as best you can yourself.
Move the modem to right where the line comes in from the ISP. If that doesn't help, they'll need to check the line
