nosamason
Nov 16, 2020Tutor
CM1000v2 Will not boot - all lights flashing rapidly
I have had this cable modem since July and it was working without any issues until a couple days ago. It seems like it will not "boot" up after powering it on. All of the lights, except for the ether...
Nov 16, 2020Guru - Experienced User
Contact a forum moderator to help you out. Seems like a hard ware problem.
Try a different power adapter with same voltate and amps to see.
- FURRYe38Nov 16, 2020Guru - Experienced User
Voltage.
- nosamasonNov 16, 2020Tutor
I tried a different power adapter, and unfortunately that didn't work. Good suggestion, though.
Sounds like the modem went bad. :smileyfrustrated:
- nosamasonNov 17, 2020Tutor
What the best way to get in touch with a moderator? The user you linked hasn't been online for 10 days.
