nosamason
Nov 16, 2020Tutor
CM1000v2 Will not boot - all lights flashing rapidly
I have had this cable modem since July and it was working without any issues until a couple days ago. It seems like it will not "boot" up after powering it on. All of the lights, except for the ether...
csrouse
Dec 07, 2020Aspirant
Just came home this evening to mine doing the same exact thing. Have tried everything to no avail. What a piece of junk.
Mrjones24
Mar 18, 2021Aspirant
Mine too. Been working great for 6 months. Woke up this morning to the same issue as everyone else.
- FURRYe38Mar 18, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Mrjones24 wrote:
Mine too. Been working great for 6 months. Woke up this morning to the same issue as everyone else.- Mrjones24Mar 18, 2021AspirantCan’t access modem connectivity page. It won’t connect to it.
ISP already checked everything else and said it’s the modem. Tried one of theirs and it worked. Definitely a hardware issue.- FURRYe38Mar 18, 2021Guru - Experienced User
Probably is then. You'll need to contact NG support to see what your options are. Good Luck.
