nsayer
Feb 23, 2024Aspirant
CM1000v2 Will not boot
We had this exact same thing happen. Xfinity had a multi-day outage, and part way through we discovered that our modem had the all-lights-blink problem.
We called Netgear support and they told ...
Feb 23, 2024Guru - Experienced User
With the ISP cable coax line disconnected, have you tried a 30-30-30 reset on the modem with nothing connected to it?
nsayer
Yup. NG support walked me through that and several other attempted actions. It continues to do nothing but the crazy-blink shortly after power-up.
- FURRYe38Feb 23, 2024Guru - Experienced User
K welp, sorry can't help beyond this. Warranty is warranty. You'll need to find another modem and move on.
- nsayerFeb 23, 2024AspirantI get that it’s out of warranty, but it *could* be repaired, even at some nominal cost. The fact that nobody will even *try* is my complaint.
Ya I wish mfrs had more repair options. Seems like router and modem Mfrs don't and rather toss it and go get another. Consumerism at it's finest. 🙄
