BraydenT113
Feb 11, 2023Aspirant
CM1000v2 won’t boot
Hello I have an issue with my modem to where the lights will all come on sequentially the internet light will blink very fast then it goes back to a blinking downstream light and repeats. I still have...
BraydenT113
No it hasn’t worked since I’ve been here and yes my provider now is through the apartment I’m at which is why I think it’s an isp issue I just wanna make sure I’m not missing something before I call them again. Also I have tried the factory reset several times no joy.
BraydenT113
Feb 12, 2023Aspirant
*update* turns out it was some kind of modem issue, I tried a different modem and it works fine now still however curious as to what could cause the modem to just go bad like that. Could it have something to do with a DIOCS 3.1 modem using lower level inputs?
- KitsapFeb 12, 2023Master
BraydenT113 wrote:
*update* turns out it was some kind of modem issue, I tried a different modem and it works fine now still however curious as to what could cause the modem to just go bad like that. Could it have something to do with a DIOCS 3.1 modem using lower level inputs?Did you need to contact your ISP and have them activate your "different" modem or did you just make the cable connection and power it up?
- BraydenT113Feb 13, 2023AspirantI didn’t have them provision that modem just plugged it in and it worked I also thought that was strange, I did however give them the MAC address for the previous modem.
- plemansFeb 13, 2023Guru - Experienced User
"for the previous modem"?
They need the one off the current modem, not the prior.
