saqer
Apr 07, 2022Aspirant
CM1100 - Intermittent Issues with Xfinity
I bought this modem from Costco a little more than a month ago. After some initial trouble getting it provisioned correctly, including a tech visit, it started working. It's been a little more than a...
- Apr 08, 2022
Your logs on indicate line issues. Its showing power fluctuations. Pretty significant ones.
saqer
Apr 07, 2022Guru - Experienced User
Your line has errors but the logs tell us the long term connection issues.
- saqerApr 07, 2022Aspirant
Tech that came the first time around a month ago checked for all that and there were a couple things he changed :
1. There was too much slack in the cable box and the cable was bent in several areas2. We removed a splitter since I no longer have Xfinity TV
So if I understand correctly, in spite of those changes there are still issues with the cable line?
