saqer
Apr 07, 2022Aspirant
CM1100 - Intermittent Issues with Xfinity
I bought this modem from Costco a little more than a month ago. After some initial trouble getting it provisioned correctly, including a tech visit, it started working. It's been a little more than a...
- Apr 08, 2022
Your logs on indicate line issues. Its showing power fluctuations. Pretty significant ones.
Apr 07, 2022Guru - Experienced User
the logs help. You didn't include those.
The line power is in spec but there's errors. the logs tell us more about stability.
