lcavey
Jan 16, 2020Aspirant
CM1100 - slow speeds
Hello All, I have signed up with Xfinity for GIG speeds. The best speeds I get from my Netgear CM1100 is 500 MBS. I also have an Orbi system connected directly via Cat 6 Ethernet cable. I had X...
Jan 17, 2020Guru - Experienced User
What model Orbi do you have connected to the CM1100.
My CM1100 works well with my Orbi AC and Orbi AX at near 900Mpbs/50Mpbs.
lcavey wrote:Hello All,
I have signed up with Xfinity for GIG speeds. The best speeds I get from my Netgear CM1100 is 500 MBS. I also have an Orbi system connected directly via Cat 6 Ethernet cable. I had Xfinity do some testing yesterday and cannot find anything wrong. Any thoughts?
Thanks!
lcavey
Jan 17, 2020Aspirant
My setup is the CM1100 to the RBK50 system. I get 450-500 mbps when I should be getting GIG speeds. Trying to determine if this is a Xfinity issue or the CM1100.
- plemansJan 19, 2020Guru - Experienced User
lcavey wrote:My setup is the CM1100 to the RBK50 system. I get 450-500 mbps when I should be getting GIG speeds. Trying to determine if this is a Xfinity issue or the CM1100.
Is this speed directly connected to the modem?
Do you have the screen snip of your modem connections page and logs?
Its hard to determine anything without more details
