Carlsonjw
Mar 21, 2019Star
CM1100 and Nighthawk X10 (R9000) Compatability with Link Aggregation
The CM1100 modem has a link aggregation feature. So does the Nighthawk X10 (R9000) router. Will the link aggregation feature work with the R9000? Netgear only lists one router that it says is compati...
Apr 05, 2019Guru - Experienced User
The R9000 only supports LAG on the LAN side. If you want to use the WAN LAG feature of the CM1100, you have to have a router that supports LAN on it's WAN side.
