Rookie1988
May 28, 2020Follower
CM1100 Connectivity Issues
First time asking a question on this forum, so I apolgoize if I am providing too much / unnecessary information. Just making sure you have everything you need to assist me. I have a CM1100 modem...
antinode
May 28, 2020Guru
> [...] the CM1100 needs to be put in bridge mode or to disable to DHCP
> mode [...]
That might make some sense if the CM1100 were a modem+router, but
it's only a modem, and, as such, has no DHCP or router capability to be
disabled.
Whatever your problem might be, it's an sbsolute certainty that
that's not the solution. A CM1100 is permanently "in bridge mode".
