Jerky_san
Aug 23, 2019Tutor
CM1100 Connects then disconnects with two amber lights on uplink
A few days ago my CM1100 appears to have started acting up. It would randomly disconnect during the night making me have to power cycle it in the morning. This came to ahead today at around 1PM when ...
Jerky_san
Aug 25, 2019Tutor
Thanks for the response. It's a coax I ran that is straight to the box a while back that I tried to make the dbmv as close to 0 as possible. The tech they sent out yesterday said the signal was one of the best he has seen. Showed me a graph showing the difference between each channel and it being a fairly straight line. We hooked my old modem up as a test and so far the old modem hasn't had any troubles. If it runs for another day or two without issue then guess I'll need to return this one.
Aug 25, 2019Guru - Experienced User
Ok, sounds just just a bad unit is all.
