nemtulea
Jan 07, 2024Aspirant
CM1100 Downstream light blinking
I have a CM1100 Cable Modem with Xfinity and have giga plan with 1.2gb downloads and 35mb uploads. For some reason while back i started to get the second led from the top blinking witch is the "Downs...
Jan 07, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
FYI, the CM1100 isn't rated for 1.2Gb ISP speeds on the down to the WAN ports are only 1000Mpbs supporting. Your ISP had a 1Gb plan up until 2022 then they did a split and came up with 800Mpbs and a 1.2 Gb plan. I highly recommend you ask the ISP to change you to the 800Mpbs plan.
- nemtuleaJan 07, 2024Aspirant
Time Priority Description 2024-01-08, 01:28:33 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2024-01-06, 01:19:28 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; 2024-01-06, 01:19:21 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2024-01-04, 13:52:56 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2024-01-03, 02:50:54 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; 2024-01-03, 02:50:47 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency <tabindex=-1>Startup Procedure</tabindex=-1> Procedure Status Comment Acquire Downstream Channel 507000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only <tabindex=-1>Downstream Bonded Channels</tabindex=-1> Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 20 507000000 Hz -1.8 dBmV 42.6 dB 25773775 0 0 2 Locked QAM256 4 405000000 Hz -2.0 dBmV 42.7 dB 24672430 0 0 3 Locked QAM256 5 411000000 Hz -2.1 dBmV 42.8 dB 24662092 0 0 4 Locked QAM256 6 417000000 Hz -1.9 dBmV 42.9 dB 24678030 0 0 5 Locked QAM256 7 423000000 Hz -2.1 dBmV 42.7 dB 24682063 0 0 6 Locked QAM256 8 429000000 Hz -2.0 dBmV 42.6 dB 24685883 0 0 7 Locked QAM256 9 435000000 Hz -2.2 dBmV 42.7 dB 24689633 0 0 8 Locked QAM256 10 441000000 Hz -2.1 dBmV 42.7 dB 24693156 0 0 9 Locked QAM256 11 447000000 Hz -2.0 dBmV 42.8 dB 24697053 0 0 10 Locked QAM256 12 453000000 Hz -2.2 dBmV 42.7 dB 24700683 0 0 11 Locked QAM256 13 459000000 Hz -2.3 dBmV 42.6 dB 24704117 0 0 12 Locked QAM256 14 465000000 Hz -2.4 dBmV 42.5 dB 24708128 0 0 13 Locked QAM256 15 471000000 Hz -2.2 dBmV 42.6 dB 24711815 0 0 14 Locked QAM256 16 477000000 Hz -1.9 dBmV 42.8 dB 24715544 0 0 15 Locked QAM256 17 483000000 Hz -2.0 dBmV 42.8 dB 24719107 0 0 16 Locked QAM256 18 489000000 Hz -2.2 dBmV 42.5 dB 24723215 0 0 17 Locked QAM256 19 495000000 Hz -1.9 dBmV 42.5 dB 24726839 0 0 18 Locked QAM256 21 513000000 Hz -1.9 dBmV 42.6 dB 24730126 0 0 19 Locked QAM256 22 519000000 Hz -1.9 dBmV 42.7 dB 24734039 0 0 20 Locked QAM256 23 525000000 Hz -1.9 dBmV 42.6 dB 24737881 0 0 21 Locked QAM256 24 531000000 Hz -1.7 dBmV 42.7 dB 24741524 0 0 22 Locked QAM256 25 537000000 Hz -1.9 dBmV 42.6 dB 24745630 0 0 23 Locked QAM256 26 543000000 Hz -2.1 dBmV 42.5 dB 24749123 0 0 24 Locked QAM256 27 549000000 Hz -2.3 dBmV 42.6 dB 24752759 0 0 25 Locked QAM256 28 555000000 Hz -1.9 dBmV 42.6 dB 24755944 0 0 26 Locked QAM256 29 561000000 Hz -1.8 dBmV 42.7 dB 24760353 0 0 27 Locked QAM256 30 567000000 Hz -1.9 dBmV 42.6 dB 24763863 0 0 28 Locked QAM256 31 573000000 Hz -2.2 dBmV 42.5 dB 24767639 0 0 29 Locked QAM256 32 579000000 Hz -2.0 dBmV 42.6 dB 24771179 0 0 30 Locked QAM256 33 585000000 Hz -1.9 dBmV 42.6 dB 24773279 0 0 31 Locked QAM256 34 591000000 Hz -1.6 dBmV 42.8 dB 24777067 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1> Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 10400000 Hz 51.8 dBmV 2 Locked ATDMA 2 16400000 Hz 51.3 dBmV 3 Locked ATDMA 3 22800000 Hz 51.0 dBmV 4 Locked ATDMA 4 29200000 Hz 51.3 dBmV 5 Locked ATDMA 5 35600000 Hz 51.3 dBmV 6 Locked ATDMA 11 40400000 Hz 52.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1> Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2, 3 48 850000000 Hz -5.8 dBmV 39.0 dB 1108 ~ 2987 24898172 24573466 0 2 Not Locked 0 0 0 Hz 0.0 dBmV 0.0 dB 0 ~ 4095 0 0 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1> Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV Current System Time: Mon Jan 07 17:37:39 2024 System Up Time: 0:09:46
