AMA123's avatar
AMA123
Follower
Apr 08, 2020
CM1100 Eero compatibility
Is the eero mesh wifi system compatible with the cm1100? The modem successfully connects via ethernet, but the eero wifi can't connect to the modem. Not sure if i have to order another wifi system.
1 Reply
  • FURRYe38's avatar
    Most home routers and wifi routers are compatible with any CM modem.
    Power OFF the modem and main host router for 30 seconds then back ON with the modem first then the main host router.
    Contact the Mfr of the Eero system and get support and help there.
