netmask001
Jun 16, 2019Aspirant
CM1100 etherchannel
I am going to be using WAPs at home. how do I connect my CM1100 to the WAPS? I want to connect the CM1100 to a cisco switch using a etherchannel. Can the CM1100 do this? Also can the CM1100 ...
antinode
Jun 16, 2019Guru
> is the CM1100 just a cable modem and router?
Half right. It's a modem. Hence there's no "router" in:
> Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem-DOCSIS 3.1
"a cisco switch" is not a very detailed description of anything.
Assuming that "a etherchannel" means an Ethernet cable, that's
probably a bad idea.
Add a router?
