wen0097
Sep 16, 2020Aspirant
CM1100 firmware upgrade (Comcast / Xfinity )
My CM1100 is running on Firmware Version V2.01.02. The connection is not stable recently. I lost the internet in the morning a few times and I can see there were two bottom lits red, and all other ...
- Sep 17, 2020
A technician came and looked at modem this afternoon, and then he verified this firmware upgrade must be pushed from ISP. He rebooted my modem but can not upgrade it.
He did call me around one hour after he left. He told me to have a "factory reset" and test it again. In fact, the factory reset solved the issue. I have Firmware Version V6.01.0 running now on it.
Sep 17, 2020Guru - Experienced User
Do you have a screen snip of the cable connections page and the logs from the modem?
post them here. it helps us to check the line.
If you have any splitters, attenuators, amplifiers, I'd recommend removing them.
FYI, firmware comes from the isp. And modem firmware changes usually aren't major changes that are going to improve stability. The CM1100 is a pretty rock solid router and had pretty solid firmware from the start so I doubt that would impact your connection stability.
wen0097
Sep 17, 2020Aspirant
