badtlc
Jul 06, 2022Aspirant
CM1100 Firmware V10.01.07 - Diagnostics No Longer Accessible
So last week my CM1100 on Xfinity updated the firmware from V7 to V10.01.07. After the update, I can no longer access the diagnostics page from my computer connected to my router. Nothing has chang...
Jul 06, 2022Guru - Experienced User
Has the modem been fully powered OFF for 1 minute then back ON?
Diagnostics page meaning the Cable connections page or the modems home page in general?
- badtlcJul 06, 2022Aspirant
Yes, it has been powered off for 1+ minute, re-plugged and turned on.
Yes. The connection diagnostics at 192.168.100.1. Nothing will load at 192.168.100.1 after the modem completes booting up. Can't even login as the page wont load.
- plemansJul 06, 2022Guru - Experienced User
You're not the first that I've seen with this issue. I'm wondering if its a new rollout that locks that away from consumers. I know spectrum has been locking that down as well.
(1) Re: Unable to access the CM1000v2 modem diagnostic... - NETGEAR Communities
It doesn't completely lock it out. I can still get to it if I connect a PC directly to the modem. It no longer works from behind a router.
