jonvall's avatar
jonvall
Tutor
Apr 18, 2020
CM1100 has 2 ethernet Ports..can I hook up my PC and router at the same time?
I'm looking to buy the CM 1100 because of the 2 ethernet ports. My only question is can I use the 1'st eathernet port for my pc connection and use the 2'nd port for my wireless router?
I've read where that's not possible so I thought I'd ask the experts.
The reason I want to do this is because the modem is next to the pc while the AC1700 is about 20 feet away, to get max coverage. If I have to use just one port then I'll have to run a 20 ft line to the router and then another back to the pc. Would really prefer not to do that. The pc is mostly a gaming pc.
Thank you in advance!
  • > [...] My only question is can I use the 1'st eathernet port for my pc
    > connection and use the 2'nd port for my wireless router? [...]
          https://community.netgear.com/t5/x/x/m-p/1894420
    > I've read [...]
       Thanks for the helpful link(s).
    > [...] Would really prefer not to do that. [...]
       As the philosopher Jagger often said, "You can't always get what you
    prefer."  (Or something similar.)
    > I've read [...]
    • jonvall's avatar
      jonvall
      Tutor
      But Jagger was wrong....you usually CAN get what you want...it'll just cost more!
      Thank you for your reply, so the solution is to hook the pc up through the router or get a modem/router then?
      • antinode's avatar
        antinode
        Guru
        > [...] so the solution is to hook the pc up through the router or get a
        > modem/router then?
           Either way, you connect one device (the router) to the modem, and all
        the client devices to that router.  Whether the modem and router are in
        the same box is unimportant.  (Unless, someday, you want a router which
        is not permanently attached to that modem.)
        > cost more!
           What _I_ want is usually includes a low price as part of its
        definition.  However, as I recall, the availability of what you _need_
        may be better.
