locnt
Jun 27, 2019Aspirant
CM1100 has speed lower than my internet provider confirmed
(Firmware Version V2.01.02) Hello, I just bought the modem. The internet went smoothly; however, the speed is much slower than expected. My Xfinity provider confirmed with me that my downl...
locnt
Jun 29, 2019Aspirant
I tried with 2 different laptops, both wired and wireless. No different results.
Should I try changing any settings?
Jun 29, 2019Guru - Experienced User
Nothing in the CM to set. LAG should be disabled is all. If you tested different PCs and such. I would presume the modem needs to be RMAd.
- vkdeltaJul 12, 2019NETGEAR Employee Retired
you dont need LAG for 60 Mbps.. LAG is for >1Gbps service.
Have you tried testing DIRECTLY to the modem?
What ethernet adapter do you use?
