Jdro86
Nov 30, 2020Aspirant
CM1100 keeps dropping connection, using Spectrum
Hi All, I bought a CM1100 about two weeks ago; it worked fine for exactly one week. Last Tuesday I had network issues, the connectivity dropped and the modem had issues re-resolving to the CMTS....
Nov 30, 2020Guru - Experienced User
Is LAG enabled on the modem?
What happens if you remove ALL splitters?
Do you have Extended Upstream Transmit Power listed on the Cable Connections page?
- Jdro86Nov 30, 2020Aspirant
LAG is not enabled.
The other line coming out of the splitter is to our cable box. I can try at some point to see if any of the diagnostics change, but might be a bit of a burden to keep the box disconnected waiting for a network drop.
I don't believe Extended Upstream Transmit Power was listed but will check later.
- Jdro86Dec 04, 2020Aspirant
Ok, removed splitter, tried plugging directly into the line. Had downstream power from 13-18. Upstream channels were between 40-41. I reinstalled the splitter immediately after and got downstream power from about 5-10; upstream was 47-48. Left it plugged into the splitter last night and had a drop again at 5AM this morning, got a warning about high power signals, and had another drop half an hour ago that didn't resolve quickly so I had to switch back to my old modem. Old DOSCSIS 3.0 TP-link modem is now getting downstream power from 4-6 and upstream are all at about 47. I have been using this modem for 4 years and have had no issues (however, modem doesn't support bandwidth upgrade, hence new modem).
I had also bought a 6db attenuator, on my CM1100 it got my downstream down to right around 0, upstream was at 53-54. I didn't have a network drop but my throughput sucked and I had a lot of uncorrectables.
Is there anything else I can do here myself? It seems to me like I am still having power issues. Should I try adding in another splitter (any recommendations on which)? I can have Spectrum come out but am skeptical that they will be able to do anything.
I should note my SNRs are 38/39 in all cases except when I added the attenuator and they were 42-43. I should also note that I have always resolved to IPv4, never to IPv6.
