Bob5545
Dec 12, 2025Aspirant
CM1100 LED Internet Infinity burnt out!
This is so annoying these LED's should never burn out. The modem is working with full internet support but the LED is not green. It is burnt out. I restarted the modem and rebooted it that light d...
Dec 12, 2025Guru - Experienced User
Use it as is.
If you need diagnosting information, you can get that from the modems web page when needed.
Some LED may have been defective at there Mfr place and just give out after a period of time.
Use as is or find something else. All warranty and non warranty issues are beyond forum help. Contact NG support for those items.
Good Luck.
