Bob5545
Dec 12, 2025Aspirant
CM1100 LED Internet Infinity burnt out!
This is so annoying these LED's should never burn out. The modem is working with full internet support but the LED is not green. It is burnt out. I restarted the modem and rebooted it that light d...
Dec 12, 2025Guru - Experienced User
I'd agree. Just use it as is if its working fine. I can't say I really use the leds. And if you're out of warranty, I'm not sure why you expect "compensation". It still works, what failed, doesn't impact performance, and its out of warranty. You don't put 150,000 miles on a car, and when the fuel pump is failing, expect the car to be replaced.
