NG_user420
Apr 18, 2020Aspirant
CM1100 Modem R7960P Router
Xfinity gigabit internet service. Not getting gigabit speed to router when running speed tests from nighthawk app. Constantly having to reboot router to get WiFi/internet connection. Ethernet speeds a...
Apr 18, 2020Guru - Experienced User
Start at square 1. Its pointless to troubleshoot a router if the modem or line is the issue.
1. What speeds do you get directly connected to the modem?
2. the R7960P has wan link aggregation. If you're using it, disable it. Link aggregation has had issues for netgear/arris/etc. its been problematic
3. Take a screen snip of the modem's cable connection page. Make sure you get all the info from that page and post it here. It shows your link back to the isp (a snap shot).
4. If you are speedtesting, don't trust the built in app's speedtest. i haven't found it even slightly reliable. Make sure what you're testing on is hardwired in and try dslreports.com or speedtest.xfinity.com The others have had issues saturating gigabit.
5. firmware on the router?
Start at these and let me know results. Like I said, its best to ensure you have full speeds at the modem and then you move on to testing the router.
- NG_user420Apr 18, 2020Aspirantplemans thank you so much for reaching out. When unplugging the modem from the router and going directly to my laptop, it doesn’t connect at all. I get the message “Ethernet has a self assigned IP address and will not be able to connect to the internet.” I agree testing the modem first is best practice, what can I do to get a working connection from the modem to the laptop?
- plemansApr 18, 2020Guru - Experienced User
Mac or PC for your laptop? for either, make sure to reboot the modem.
Mac:
https://support.apple.com/guide/mac-help/connect-mac-internet-a-cable-modem-mchlp1460/mac
windows:
you should just need to reboot the modem with nothing connected and then connect the pc.
- NG_user420Apr 18, 2020AspirantThat was the first move I made and it was successful. Now on chat with xfinity to verify my speeds. Will get back shortly with an update. To answer your question, I have 3 different MacBooks that I can try
