NG_user420
Apr 18, 2020Aspirant
CM1100 Modem R7960P Router
Xfinity gigabit internet service. Not getting gigabit speed to router when running speed tests from nighthawk app. Constantly having to reboot router to get WiFi/internet connection. Ethernet speeds a...
NG_user420
plemans thank you so much for reaching out. When unplugging the modem from the router and going directly to my laptop, it doesn’t connect at all. I get the message “Ethernet has a self assigned IP address and will not be able to connect to the internet.” I agree testing the modem first is best practice, what can I do to get a working connection from the modem to the laptop?
Apr 18, 2020Guru - Experienced User
Mac or PC for your laptop? for either, make sure to reboot the modem.
Mac:
https://support.apple.com/guide/mac-help/connect-mac-internet-a-cable-modem-mchlp1460/mac
windows:
you should just need to reboot the modem with nothing connected and then connect the pc.
