NG_user420
Apr 18, 2020Aspirant
CM1100 Modem R7960P Router
Xfinity gigabit internet service. Not getting gigabit speed to router when running speed tests from nighthawk app. Constantly having to reboot router to get WiFi/internet connection. Ethernet speeds a...
Apr 18, 2020Guru - Experienced User
Mac or PC for your laptop? for either, make sure to reboot the modem.
Mac:
https://support.apple.com/guide/mac-help/connect-mac-internet-a-cable-modem-mchlp1460/mac
windows:
you should just need to reboot the modem with nothing connected and then connect the pc.
NG_user420
That was the first move I made and it was successful. Now on chat with xfinity to verify my speeds. Will get back shortly with an update. To answer your question, I have 3 different MacBooks that I can try
- plemansApr 18, 2020Guru - Experienced User
If you log into the modem (192.168.100.1) and click on cable connection, take a screen snip of that and the logs. Post that back here.
And then speedtest it off the sites I recommended.
- NG_user420Apr 18, 2020Aspirant
plemans Confirmed with Comcast over 900mbps coming from modem to laptop.
i then reconnected cm1100 modem to R7960P and am getting the following WiFi speeds:
- speedtest.xfinity.com = 317mbps
- dslreports.com = 195mbps
tried posting links to the cable connection and logs of the modem, but I guess those are trapped awaiting approval.
please let me know what you would like to see from the router. I can confirm I have all port aggregation disabled.
thank you!!
NG_user420 wrote:plemans Confirmed with Comcast over 900mbps coming from modem to laptop.
thank you!!
Make sure you're testing hardwired speeds from the router. Not wifi. Wifi is dependant on device, environment, interference, etc. to many things influence the speed and wireless AC isn't going to max out gigabit.
