NG_user420
Apr 18, 2020Aspirant
CM1100 Modem R7960P Router
Xfinity gigabit internet service. Not getting gigabit speed to router when running speed tests from nighthawk app. Constantly having to reboot router to get WiFi/internet connection. Ethernet speeds a...
NG_user420
Jun 23, 2020Aspirant
https://speedtest.xfinity.com/devicespeeds
Use this link to verify max speeds per device. Your device may not be able to handle the speed being sent to it and is hitting its own ceiling.
For what it is worth, I have not been able to get this solved for either. My 2019 MacBook Pro is showing WiFi speeds of 101 mbps on a gig internet plan.
VgsSchade
I am comparing a wired connection from my modem to a wired connection from my router, it seems my router is cutting my bandwidth in half using the same cables.
If that is the case then this router does not do its advertised speeds.
- FURRYe38Jun 23, 2020Guru - Experienced User
Is Smart Connect enabled on the R7960P?
Try disabling Smart Connecxt and connect to the 5ghz radio.
Enable Beamforming and make sure WMM is enabled as well.
Yes some wifi devices max out at around 400 to 500Mbps on 5Ghz AC.
Always test the wire connection first.
- VgsSchadeJun 23, 2020Aspirant
I am direct conneted to my router with a cat 6 cable, it only gives me 350 megs, If i connect the same computer direct to my modem with the same cable I get 1.1gig.
Have you tried a speed test after a factory reset?
Heres my speed test, wired PC connected to my R7960P connected to a CAX80 modem.
VgsSchade wrote:I am direct conneted to my router with a cat 6 cable, it only gives me 350 megs, If i connect the same computer direct to my modem with the same cable I get 1.1gig.
Firmware V1.4.1.50_1.3.10
I have done a factory reset but still stuck at just under 350 megs.
- FURRYe38Jun 24, 2020Guru - Experienced User
Have you powered OFF the modem as well for 1 minute then back on?
Is this result with just 1 PC or have you tried a different PC?
Swap out LAN cables between the modem and router and PC? Cat 6 is recommended.
After the reset, did you enable anything like Armor, Access Controls, QoS or Traffic Meter?
VgsSchade wrote:Firmware V1.4.1.50_1.3.10
- VgsSchadeJun 24, 2020Aspirant
yes, all rebooted, cat6 is the only cabling attatched from the modem to the router and from the router to my computer.
traffic meter, armor, qos, access controls are all disabled.
- FURRYe38Jun 25, 2020Guru - Experienced User
Something i would file a support ticket about with NG and get help and informaton regardfing the router. Seems to be a router issue.
VgsSchade wrote:yes, all rebooted, cat6 is the only cabling attatched from the modem to the router and from the router to my computer.
