Larry2024
May 07, 2024Guide
CM1100 need to reset modem constantly with COX
Hi all, used to be every few days but now I am having to reset the modem multiple times a day and it is driving me nuts. Here is the connection after a factory reset. Many thanks! Startup P...
- Jun 06, 2024
Looks good. Some channels are a bit far in power between the channels however if it's working. Let it run.
May 08, 2024Guru - Experienced User
The levels are also all over the place. They should be within 3.5dbmv of each other.
Something is squirrelly with the line.
- Larry2024May 08, 2024Guide
Thank you all for the reply. Cox tech came out this morning, he said the cable from the outside to the house needs to be replaced (he measured and said there is a 90% power drop).
He said to take care of this first and if issue still occur afterward than he can add a new cable from my house to where the modem is located.
Will report back and share the new connection status once the cable is replaced.
- FURRYe38May 08, 2024Guru - Experienced User
That should help as well the the correctables and un-correctables as those should be zeros across the board.
Also have the tech check the modems events logs. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
- KitsapMay 08, 2024Master
Larry2024 wrote:Thank you all for the reply. Cox tech came out this morning, he said the cable from the outside to the house needs to be replaced (he measured and said there is a 90% power drop).
Sounds like a worthwhile tech visit. If your internal wiring, splitters, and etc. are more than a half dozen years old, it would be worthwhile to push to have that also replaced.
- Larry2024May 23, 2024Guide
Cox said it will take up to 12 weeks to replace the outside line (need city permit) but funny thing happened yesterday, ATT Fiber crew outside digging holes to install fiber cables and they severed my Cox line. Spent a few hours tried to reconnect the cables but the hack job failed so today they replaced the outside line. Here is the new connection status:
Startup Procedure Procedure Status Comment Acquire Downstream Channel 237000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv4 only Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 45 237000000 Hz 7.9 dBmV 45.5 dB 407147168 0 0 2 Locked QAM256 1 735000000 Hz 5.8 dBmV 43.0 dB 405955455 0 0 3 Locked QAM256 2 741000000 Hz 6.2 dBmV 43.1 dB 405957909 0 0 4 Locked QAM256 3 747000000 Hz 5.5 dBmV 43.2 dB 405962269 0 0 5 Locked QAM256 4 753000000 Hz 5.9 dBmV 43.4 dB 405967522 0 0 6 Locked QAM256 5 759000000 Hz 6.1 dBmV 42.6 dB 405970697 0 0 7 Locked QAM256 6 765000000 Hz 5.5 dBmV 42.8 dB 405974568 0 0 8 Locked QAM256 7 771000000 Hz 6.1 dBmV 43.5 dB 405978494 0 0 9 Locked QAM256 8 777000000 Hz 5.6 dBmV 43.1 dB 405982016 0 0 10 Locked QAM256 9 783000000 Hz 5.3 dBmV 43.1 dB 405985763 0 0 11 Locked QAM256 10 789000000 Hz 5.8 dBmV 43.4 dB 405989383 0 0 12 Locked QAM256 11 795000000 Hz 5.0 dBmV 43.0 dB 405993444 0 0 13 Locked QAM256 12 801000000 Hz 5.2 dBmV 43.1 dB 405997121 0 0 14 Locked QAM256 13 807000000 Hz 5.4 dBmV 43.4 dB 406000515 0 0 15 Locked QAM256 14 813000000 Hz 4.6 dBmV 42.9 dB 406003992 0 0 16 Locked QAM256 15 819000000 Hz 5.0 dBmV 43.1 dB 406009090 0 0 17 Locked QAM256 16 825000000 Hz 4.4 dBmV 42.8 dB 406012238 0 0 18 Locked QAM256 17 831000000 Hz 3.8 dBmV 42.3 dB 406015861 0 0 19 Locked QAM256 18 837000000 Hz 4.5 dBmV 42.8 dB 406019314 0 0 20 Locked QAM256 19 843000000 Hz 3.8 dBmV 42.4 dB 406023755 0 0 21 Locked QAM256 20 849000000 Hz 3.6 dBmV 42.2 dB 406026816 0 0 22 Locked QAM256 21 855000000 Hz 4.2 dBmV 42.6 dB 406030843 0 0 23 Locked QAM256 22 861000000 Hz 3.5 dBmV 42.2 dB 406034184 0 0 24 Locked QAM256 23 867000000 Hz 3.6 dBmV 42.3 dB 406038450 0 0 25 Locked QAM256 24 873000000 Hz 3.6 dBmV 42.1 dB 406041580 0 0 26 Locked QAM256 25 117000000 Hz 7.8 dBmV 44.5 dB 406045933 0 0 27 Locked QAM256 26 123000000 Hz 7.9 dBmV 44.6 dB 406049785 0 0 28 Locked QAM256 27 129000000 Hz 8.1 dBmV 44.9 dB 406053601 25 0 29 Locked QAM256 28 135000000 Hz 7.9 dBmV 45.0 dB 406057292 1 0 30 Locked QAM256 29 141000000 Hz 7.8 dBmV 45.3 dB 406060707 0 0 31 Locked QAM256 37 189000000 Hz 7.9 dBmV 45.4 dB 406058719 0 0 32 Locked QAM256 40 207000000 Hz 8.0 dBmV 45.5 dB 406059741 0 0 Upstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 16900000 Hz 37.3 dBmV 2 Locked ATDMA 2 23500000 Hz 37.8 dBmV 3 Locked ATDMA 3 29900000 Hz 37.5 dBmV 4 Locked ATDMA 4 36300000 Hz 38.0 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2, 3 159 300000000 Hz 7.3 dBmV 43.3 dB 296 ~ 7895 1623753096 32953507 0 2 Locked 0, 1, 2, 3 160 918000000 Hz 3.4 dBmV 40.0 dB 1108 ~ 2987 186671750 57723114 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Locked 3, 4, 9, 10, 11, 12, 13 6 36800000 Hz 32.3 dBmV 2 Not Locked 3, 4, 9, 10, 11, 12, 13 0 0 Hz 0.0 dBmV Current System Time: Thu May 23 13:41:58 2024 System Up Time: 2:29:43
