Larry2024
May 07, 2024Guide
CM1100 need to reset modem constantly with COX
Hi all, used to be every few days but now I am having to reset the modem multiple times a day and it is driving me nuts. Here is the connection after a factory reset. Many thanks! Startup P...
- Jun 06, 2024
Looks good. Some channels are a bit far in power between the channels however if it's working. Let it run.
May 08, 2024Guru - Experienced User
The levels are also all over the place. They should be within 3.5dbmv of each other.
Something is squirrelly with the line.
Larry2024
May 08, 2024Guide
Thank you all for the reply. Cox tech came out this morning, he said the cable from the outside to the house needs to be replaced (he measured and said there is a 90% power drop).
He said to take care of this first and if issue still occur afterward than he can add a new cable from my house to where the modem is located.
Will report back and share the new connection status once the cable is replaced.
