Larry2024
May 07, 2024Guide
CM1100 need to reset modem constantly with COX
Hi all, used to be every few days but now I am having to reset the modem multiple times a day and it is driving me nuts. Here is the connection after a factory reset. Many thanks! Startup P...
- Jun 06, 2024
Looks good. Some channels are a bit far in power between the channels however if it's working. Let it run.
May 23, 2024Guru - Experienced User
Seems still a bit all over the place in power levels. Some channels are a bit too high. Something you can try get a -6Dbm coax line attenuator in put behind the modem and see if this gets the power down for those channes.
Correctables and Un-currectables are way better though.
Larry2024
May 23, 2024Guide
Thank you FURRYe38, just ordered one from Amazon, will report back when in a couple of days.
I really appreciate everyone's help!
