Larry2024
May 07, 2024Guide
CM1100 need to reset modem constantly with COX
Hi all, used to be every few days but now I am having to reset the modem multiple times a day and it is driving me nuts. Here is the connection after a factory reset. Many thanks! Startup P...
- Jun 06, 2024
Looks good. Some channels are a bit far in power between the channels however if it's working. Let it run.
Jun 05, 2024Guru - Experienced User
Yes.
Good on the correctables and un-correctables.
Hows the event log look?
Larry2024
Jun 05, 2024Guide
Only Notice, there is no warning or critical...
- FURRYe38Jun 05, 2024Guru - Experienced User
- Larry2024Jun 06, 2024Guide
Up for 19 hours and all the channels with above 7 dBmv started to accumulate correctables and un-correctables, with notice events only. I just added the 3db attenuator and will let it run for a day to see if it is any better. If not I will put the 6db on. This is the connection status with the 3db. Thanks!
- FURRYe38Jun 06, 2024Guru - Experienced User
- Jeffrey123Jun 24, 2024Aspirant
Just wanted to see if your connection is still good. I too am in Phoenix area and have been the same problem as you. I have cox coming out next week, so hopefully it can get resolve.
- Larry2024Jun 24, 2024Guide
Hey there, unfortunately it worked good for a few weeks with the new outside line and the 3db attenuator. Lately I am experiencing T3 errors and dropped connections with correctable and uncorrectable codewords on all channels. What works for me now is a daily modem reboot just to keep the connection up for the day. I have also removed the attenuator.
I am just going to tough it out and switch to ATT Fiber as soon as it is rolled out to my neighborhood.
I'm hoping that Cox can fix the problems for now. I will however be looking into AT&T once they finally roll out. They have just now started to run lines down my street. Also hopeful that they comparably priced.
Not sure if you are aware of this but cox will charge you if the tech determines the issue is inside your house. I added the $10 a month Cox complete care prior to them coming out. I canceled it only after the tech said I need a new outside line.
I am paying close to $100 for Cox 1 gig service with a 1280GB data plan. I think ATT is about the same price but with unlimited data plan.
