Larry2024
May 07, 2024Guide
CM1100 need to reset modem constantly with COX
Hi all, used to be every few days but now I am having to reset the modem multiple times a day and it is driving me nuts. Here is the connection after a factory reset. Many thanks! Startup P...
- Jun 06, 2024
Looks good. Some channels are a bit far in power between the channels however if it's working. Let it run.
Larry2024
Jun 24, 2024Guide
Hey there, unfortunately it worked good for a few weeks with the new outside line and the 3db attenuator. Lately I am experiencing T3 errors and dropped connections with correctable and uncorrectable codewords on all channels. What works for me now is a daily modem reboot just to keep the connection up for the day. I have also removed the attenuator.
I am just going to tough it out and switch to ATT Fiber as soon as it is rolled out to my neighborhood.
Jeffrey123
Jun 24, 2024Aspirant
I'm hoping that Cox can fix the problems for now. I will however be looking into AT&T once they finally roll out. They have just now started to run lines down my street. Also hopeful that they comparably priced.
- Larry2024Jun 24, 2024Guide
Not sure if you are aware of this but cox will charge you if the tech determines the issue is inside your house. I added the $10 a month Cox complete care prior to them coming out. I canceled it only after the tech said I need a new outside line.
I am paying close to $100 for Cox 1 gig service with a 1280GB data plan. I think ATT is about the same price but with unlimited data plan.
