subquest
Mar 17, 2023Guide
CM1100 No Longer Compatible with Xfinity Due to Security Software
Xfinity sent out an email that my CM1100 modem is no longer compatible with the 800 Mbps plan even though the specs on the device exceeds that. Xfinity's initial reason was due to INCOMPATIBLE BASED...
DarrenM
Mar 17, 2023Sr. NETGEAR Moderator
Have you checked to see if the speeds have changed?
DarrenM
- subquestMar 17, 2023GuideI have been running a number of different speed test. It has been bouncing around a little more and has been a little lower, especially with Xfinity's soeed test. I was at 600 Mbps plan and saw upper 500s Mbps into 700s Mbps range. Test over last day been more mid 500s Mbps but the one I just ran went over 700 Mbps again. I can't help to wonder if Xfinity sends out the notice and does something.
- FURRYe38Mar 17, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerBe sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/ISPs don't seem to notify there users of any changes in service sometimes.
I'd contact the ISP to check to see which speed tier they have you on. CC/XF changed there speed tiers last year and seem to have removed the 1GB plan and split it into a 800Mb and 1.2Gb plan. This cause some issue with other NG products that don't support 1.2Gb speeds with 1Gb max supporting products.
Firmware - V10.01.07
Hardware - 2.02
Router TP-Link AX3200 Tri-Band
In looking through the logs, did raise a question regarding posting. I see MAC addresses etc. that I wonder if shouldn't be posted. What is the risk level of sharing the modem connection status and event log page? Is there something I should be looking for?
I am currently using a CAT 5e cable... I was previously on 600 Mbps plan that they are bumping to 800 Mbps. With getting close to 1 GB probably makes sense to swap in a CAT 6 cable. The distance I need is only around 15 feet. Any CAT 6 cable recommendation and are there any on Amazon that are good?
- KitsapMar 17, 2023Master
subquest wrote:
I have been running a number of different speed test. It has been bouncing around a little more and has been a little lower, especially with Xfinity's soeed test. I was at 600 Mbps plan and saw upper 500s Mbps into 700s Mbps range. Test over last day been more mid 500s Mbps but the one I just ran went over 700 Mbps again. I can't help to wonder if Xfinity sends out the notice and does something.For testing throughput capacity, recommend using the Ookla native operating system application for your device. It is very consistent and removes the web browser variances from the process. The application is available from the play stores.
Test results can vary from time of day to time of day. It would not be unusual to see values change plus or minus 75 Mbps.
Thank you for the Ookla speed test recommendation. It looks like a great tool to use, but must admit a little nervous ask for permission to make and manage phone calls.
I see it states... Speedtest will never make or manage your phone calls. Our app requests this permission to determine your cellular connection and provider in order to display that information in your test result.
