subquest
Mar 17, 2023Guide
CM1100 No Longer Compatible with Xfinity Due to Security Software
Xfinity sent out an email that my CM1100 modem is no longer compatible with the 800 Mbps plan even though the specs on the device exceeds that. Xfinity's initial reason was due to INCOMPATIBLE BASED...
subquest
Mar 22, 2023Guide
Missed info:
| Current System Time: Wed Mar 22 13:55:26 2023 |
| System Up Time: 905:10:48 |
I believe xfinity/comcast, but not positive the same date, might of had an issue around that time as I had where my X1 player lost internet connection and the modem went out at the same time. I am not aware of them being tied together in anyway. My X1 eventually came back, but I had to reboot the modem.
Kitsap
Mar 22, 2023Master
subquest wrote:Missed info:
Current System Time: Wed Mar 22 13:55:26 2023 System Up Time: 905:10:48
The system up time seems quite odd to me. If someone asked you how long it has been since you rebooted your modem, what would you say?
Have you sent the requested information to DarrenM ??
- subquestMar 24, 2023GuideYou raise sn interesting question... I have pulled the power to the modem, waited a number of minutes and then powered back up within the last month. I have not done a reboot through my Xfinity or using the modem interface. Does powering down and back essentially do the same thing?
Full circle... just received another email about my modem is no longer compatible.
Not yet due to comfort level of providing Mac address. I assume name would be good enough as xfinity can look up my Mac. I do have a question... dealing with Xfinity support has been very painful in the past. I have spent hours on the phone being passed from one person to the next or being mysteriously dropped when a solution could not be found. One time we spent several hours trying to get tv boxes to work and then later a new modem, when we did finally get a person on the line that knew their stuff, my wife broke down it tears. We explained the guy why and he was proud he could help and explained that he was very aware of the challenges many face. All this being said... is there a way to engage Xfinity support that you reach knowledgeable people that are able to help without first going through all the difficult layers people going off of scripts? - subquestMar 24, 2023GuideThanks!
I am not sure who all the players are and their roles. Is someone tied to or was able to let the right Netgear people know about the CM1100 being indicated as no longer compatible by Xfinity so they can discuss it with them? - FURRYe38Mar 24, 2023Guru - Experienced User
Just make contact with Darren.
Good Luck.
- KitsapMar 24, 2023Master
Maybe just cynical on my part. Intentional deceptive communication from Comcast. The CM1100 is compatible with the Comcast system (DOCSIS 3.1). It is not compatible with the top throughput tier you can purchase from Comcast unless you use link aggregation. Fine points Comcast chooses to ignore.
Many users have been deceived by the communications and purchased items or plans they did not need or want. In particular senior citizens or users with less technical knowledge. Marketing and ethics are terms not usually found in the same sentence.
- subquestMar 24, 2023GuideTo support your point... yesterday I got an email indicating my CM1100 modem is no longer compatible. Today I got an email all about xFi Gateway... coincidence... I don't think so.
- Marty1330Apr 25, 2023Aspirant
Hello. I too have a CM1100 connected to Comcast/Xfinity "Superfast" (800Mbps) internet. We received an email from Xfinity on 3/14 informing us that our internet speed had been increased (to 800Mbps) and that our "internet equipment is not able to deliver these new speeds." AFAIK, the CM1100 is completely capable of handling sub-gig speeds (even greater!).
Perhaps not so coincidentally, around that timeframe it seems that we started to experience frequent network performance notifications from our streaming devices (e.g., FireTV) and my video conference calls have been regularly freezing or even dropping due to lost WiFi connection. I was thinking it was our router (Linksys EA8300), but last night we lost internet at the CM1100 and couldn't get it back until I swapped it out for previous modem (SB6141). The internet connection has been stable since.
I began to research issues with the CM1100 and that lead me to this thread. The indicators on the CM1100 appear to be normal, but I will admit that I didn't inspect the logs prior to swapping it out. Has Xfinity/Comcast done something to impact the operation or compatibility of the CM1100 with their network? Does it need a FW update? If so, how do I get it if it won't even connect to their network?
My CM1100 has only been in service 15-16 months and all visual indications are that it's still operational. I dread trying to troubleshoot this with Comcast support. Can anyone on this thread help (I'm looking at you DarrenM 😉)?
Thanks in advance for any assistance or guidance you can offer.
- FURRYe38Apr 25, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Hi FURRYe38. Thanks for your reply.
As I recall, the FW was v1.0 and the last time I checked (months ago) there wasn't an update available. I heard that the modem FW was controlled by Comcast, not the modem manufacturer.
I'll have to take down my network to swap in the CM1100 and then call Comcast to re-authorize it (I think). Will have to wait for some down-time around the house. You'll know better than me, but I suspect that the modem will clear the event log after it boots.
Ya, give the modem 10-15 minutes of being online then collect the logs.
Be aware that CC and XF changed there speed tier plans last year. They seem to have removed the 1Gb plan and split into a 800Mpbs and 1.2Gb plan. I know that some areas still have the 1Gb service. I presume eventually the ISP will phase that out nation wide. The CM won't support the 1.2Gb tier. 800Mpbs is well supported though.
- subquestApr 25, 2023Guide
I have been carefully watching and tracking my speeds ever since doing the original post. The speeds do seem to bounce around more, but so far I have not had issues with things dropping or freezing. At times I am even now seeing speeds over 800Mbps. Every now and then I do still get the Xfinity No Longer Compatible with Xfinity email followed next day or two with a new hardware offer.
I checked my CM1100 modem...
Hardware Version 2.02 Firmware Version V10.01.07 Was anyone from Netgear able to get information from Xfinity? Basically... do I need to start worrying again or am I okay until DOCSIS 3.1 is no longer supported?
I did check my Event log and only had 1 day in last two months that had a few events.. though it may be the day Xfinity truck stopped at the main box on road and my modem went down and then back up just before they left:... though there is a later time too... any concerns?:
2023-04-11, 19:33:25
Critical (3)
Started Unicast Maintenance Ranging - No Response received - T3 time-out; CM-QOS=1.1;CM-VER=3.1;
2023-04-11, 16:33:02
Critical (3)
UCD invalid or channel unusable;;CM-QOS=1.1;CM-VER=3.1;
2023-04-11, 16:33:01
Notice (6)
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;;CM-QOS=1.1;CM-VER=3.1;
2023-04-11, 16:32:52
Notice (6)
Honoring MDD; IP provisioning mode = IPv6
2023-04-11, 16:32:48
Critical (3)
2023-04-11, 16:32:06
Notice (6)
2023-04-11, 16:31:53
Critical (3)
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;;CM-QOS=1.1;CM-VER=3.1;
Any insights to what these mean would really be appreciated!
- FURRYe38Apr 26, 2023Guru - Experienced User
Please post a copy and paste of the modems full connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-routerI see Criticals that the ISP needs to review and resolve. Any Errors or warnings should be reviewed as well.
https://highspeed.tips/docsis-events/
Will know more as well after you post the cable connections status page info here.
- FURRYe38Apr 27, 2023Guru - Experienced User
Ok, power levels are with in spec:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
I see some Correctables however there not bad. Should be mostly zero so there is some minor line issue seems like.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlUnless the ISP is pushing to the 1.2Gb plan which the CM wouldn't fully support, 1Gb or lower speed tier should work with the CM modem. I know that XF seemed to have removed the 1Gb tier from some areas of service and are now pushing a 800Mpbs and 1.2Gb tiers. 800Mbps should be compatible and supported by the ISP unless they are not supporting any DOCSIS 3.1 modems which I highly doubt. There marketing dept I persume would be giving false information or pushing users to use higher speed teirs when they don't really need too.
- subquestApr 27, 2023Guide
Router TP-Link AX3200 Tri-Band
The link to provide insights to event log was helpful, but not sure I fully understand exactly what these are and what causes them:
- UCD invalid or channel unusable
- Started Unicast Maintenance Ranging - No Response received - T3 time-out
- Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time
Would these occur if Xfinity had disconnected temporarily out at the main box?
Most definitely. Most items seen in the event logs are on the modem side so ISP should know about all those and how to resolve them.
Did you make contact with the forum moderator that asked you to PM him some ISP account info?
