Rstrauss
Oct 25, 2020Aspirant
Cm1100 not working with netgear routers
Just got the cm1100 modem activated by optimum direct connect computer is fine, but it won’t work with either router. Can someone advise?
Rstrauss
Thank you-I was using all same set up as previous just using the new modem (to get away from the optimum modem. I was trying to avoid a router reset with all of the connected devices...but the only way to get the router to recognize the modem was so do a reset on the router and follow the nighthawk app reset. Now all is fine.
I have the xr500 but wasn’t really happy with it so went back to the r8500.
Oct 25, 2020Guru - Experienced User
To get the XR router to work right, you have to power cycle the XR router off for 30 seconds then back ON after the CM modem is already online. XR routers or kind of odd this way. I have the X450 and to get it to connect right, it has to be power cycled after being connected to the modem.
