Oswulf
Jun 23, 2020Aspirant
CM1100 Rebooting
So my modem has rebooted three times in the last 45 minutes. I have attached the log...and the current signals This was happening a couple weeks ago and Comcast just kept saying everything was o...
Jul 09, 2020Guru - Experienced User
Well ISPs will say anything or blame the HW when its there issue. Try a different modem then see what happens. if you still have problems, you'll need to get a tech on site and have them take a closer look.
Oswulf
Jul 10, 2020Aspirant
So, if you were buying another Modem today, what would you get? Currently I have CM1100. Only 300Mbps service today but probably going 1GBp. Seems there are basically three choices:
Arris 8200
Motorola 8600
Netgear CM1200
(I have Orbi Mesh Wifi 6 so just modem then)
- FURRYe38Jul 11, 2020Guru - Experienced User
Try any one of them. You may have a faulty CM modem which needs to be either replaced or looked at by NG.
IF the others work for you then you'll know. If they exhibit the same problem, then something on the ISP line needs to be looked at.
I can tell you that my CM1100 worked for a long while before putting a different modem online. It's a solid modem. I enjoy the two network ability of it. I belive the CM1200 does the same thing. Try something else to see if the problem continues or not. Then you'll know what direction to go towards.
